Hi Rob,
The 'Estimated Processed Accuracy' values in TerraFlex indicate that you have Offline GNSS Corrections enabled for your project. This is an alternative GNSS correction source that can be used alongside real-time GNSS corrections, and works by logging raw GNSS measurements in the field and then processing those in the cloud after. This process relies on GNSS measurements from another source, e.g. a base station network, to be used as part of processing the measurements. You can see here which base stations are available for TerraFlex to use, in the UK the OSNet network is available while in Türkiye there are much fewer base stations available.
The RMS error is based on a 68% confidence interval, or if you were to log 100 positions on a point then 68% of them should have actual error less than the error estimate. We talk about the different sources of error in our blog post here that can impact the quality and accuracy of a position the GNSS receiver generates, and it is these sources that directly impact the accuracy value you see in TerraFlex.
The Trimble DA2 Spec Sheet outlines the expected performance when using RTX corrections. For Catalyst 1 the specification is 2cm RMS horizontal error, and 5cm RMS vertical error. There is an important footnote there noting that there are a number of factors that can impact achieving this value - for example you should not expect to achieve this level of performance operating under tree canopy where there are a number of obstructions that can contribute to increased error. I would guess that mountain summits generally have a clear view of the sky/satellites and so you are more likely to achieve this level of performance!
For Catalyst 60 the performance you can expect is limited by your Catalyst license, in this case to 60cm RMS. This is regardless of the GNSS correction technology that you are utilizing, and has the same requirements mentioned above regarding GNSS conditions etc.
If you have any further questions please add them here and I can try and answer
Thanks
Hamish MacMillan
TerraFlex Product Manager
