Hi Anna,
Per our direct messages I'm glad you were able to resolve this through updating TMM and setting the GNSS output manually to the required reference frame. I'll close this thread now.
Best regards,
Mark Kellaway
Sent: 07-24-2023 13:17
Subject: Da2 Recievers and Field Maps Discrepancies between TDC600 and iPhone SE
This is the only log file I was able to send through.
Anna Peters
Sent: 07-24-2023 13:03
Sorry it took me a while to get back to you. I have tried to send the log files but it never comes through to my email! I did try switching both devices and have come up with the same result when pairing the recievers to each device.
Anna Peters
Sent: 05-01-2023 14:56
Hi Anna,
A constant offset in one direction would imply a coordinate system mismatch. Could you please run TMM on each device without Field Maps, connect to the receiver, then share the log file from each device (About menu, Send Log File). Please feel free to share these with me directly rather than in the thread.
Best regards,
Mark Kellaway
