Yes, I realize that. I had commented earlier that I too was having issues with Connect. I meant my forms and data are now in connect available for use.
Sent: 10-23-2023 06:10
Subject: data collected in Terraflex not appearing in trimble connect
Hi Kara
There should be no problem syncing forms. If you are unable to sync forms from the device then I'd recommend you contact your local Trimble reseller for help working through this
This thread specifically addresses sync'd forms that are not appearing in the Map Viewer.
We're currently processing through the backlog so I would check again tomorrow
Tom Harrison
Sent: 10-23-2023 05:41
I just checked this morning and my forms haven been synced.
Kara O'Neill
Sent: 10-23-2023 04:27
Hi Chris and anyone else following this thread
We're working through the backlog of unprocessed forms at the moment and hope to have this cleared by tomorrow. If you check your Map Workspace tomorrow, we expect all the outstanding forms will be visible
Terraflex users can continue to synchronize forms to Map Viewer, this issue related specifically to the forms being processed and stored
We apologise for any inconvenience whilst this is resolved
Tom Harrison
