The problem was caused by using some other than default location for the Trimble Connect local folder.
Sent: 04-22-2025 01:33
Subject: Datatable not working on visible objects
Hi @Tibor Kovacs,
I contacted Trible Connect Support. Apparently, this issue does not concern only me.
I guess we'll get an update soon : )
Sent: 04-15-2025 12:58
Hi Marcin, this looks like a different problem and definitely should not be like that. Not even the translations are working in your case and Data Table doesn't receive any data at all from the application. It's as if something went very wrong during the initialization of the Data Table component.
Can you create a Connect support issue about this? With details if it ever worked for you, when did it start to happen, is it model / project specific...
(If you don't know how to create a support issue, to be honest I never did it, but try this: https://community.trimble.com/viewdocument/trimble-connect-support#MainCopy_ctl10_lblIsPinned )
Tibor Kovacs
Sent: 04-15-2025 08:43
Hi Guys,
I'm having a similar issue but with TC Desktop.
The Data Table does not work no matter what (Part/assembly selection, selected/all objects). Is it a bug?
Sent: 04-11-2025 07:38
Hi everyone,
Please try it now. A fix has been deployed today (11th of April). If your browser picks up the new version - normally it should, if not then clearing the cache is the last resort - then will work again. Steven, you probably are among the first ones who found it out.
Tibor
Tibor Kovacs
Sent: 04-11-2025 03:27
I had the same problem. Just cleared the cache for trimble connect and "visible objects" now works again.
Ste
Steven Jackson
Sent: 04-10-2025 07:18
Same here, doesn't matter if the assembly is on or off.
Marco Perazzo
Sent: 04-07-2025 07:49
Try turning off 'Assembly' selection on the top tool bar and see if it can read the parts data.
Ruben Flores
Technical Director
TRC Worldwide Engineering, Inc.
217 Ward Circle
Brentwood, TN 37027-2314
Cell – 325-320-0719
rflores@trcww.com
http://www.trcww.com
