Mike, Mike,
Excellent response and had to post in this forum due to the incredible receivers and support Trimble provides the user.
What I find shocking is so little attention is given to, like you said "checking into control". The simple app Quick Capture is a lightning fast app to teach to old and new comers on the cycle from Pro to AGOL and back down again. In fact most of my data points in this test were from a 8 person class, moving around on a control network and simply pressing a button, pre-configured with Receiver/Augmentation/MiddleWare/MobileApp and monitored for proper antenna placement. So simple to do in actual practice, and everyone can see back after the field what they did. Back in the day, without the melding pot called AGOL, a GPS class could only peer over at their neighbors monitor and see what they did and how close they were on the mark. On average 70% of the class hit the bullseye, the other 30% let out a "...hmm, whats going on?"
We really can't blame the thousands using these tools with the internet stuffed with "Hi-Accuracy workflows". Watch any video out there and no one is mentioning the GCS of the basemap, which as you know, is the controlling factor in the big 3 mobile workflows. Combine this with a "combo" workflow, using say Field Maps with Survey 123, and you have a recipe for storing incredibly precise data 1 meter away.
NGS now has the fix, with access to NAD83(2011) control on their rest services, and OPUS SHARE. It's just getting data to that "right spot" that has so many levers to pull. It is great to read your last paragraph. We should all be concerning ourselves on datum handling, and less about how cool a software is and be more precise and accurate in support documentation in achieving the steps to get there. Impossible to do without checking into survey control. Can you imagine the confusion in 2026 if we don't know where the data is going right now?
Joel Cusick
Sent: 04-19-2024 06:26
Subject: Datum shift in ESRI QuickCapture
Joel, thanks for reposting this in this forum. We have used The R1 and R2 along with Collector, and now Field Maps on both iOS and Android devices using the companion apps of GNSS Status, the Trimble Mobile Manager. Our objective is to always achieve the best accuracy possible with the available equipment and software. We see the same challenges that you do regarding multiple changing settings requirements, software app updates and the general complexity of the processes happening in the background. Too little effort, we think, has been taken by the software/hardware developers and the sales support community to ensure this process to achieve high accuracy is streamlined and understandable.
It is great that ESRI and Trimble has, or once did have, a team that worked jointly on the development of this field data collection process. But, this type of system problem seems to continue over the years.
We try to always include check in points to known monumentation as a part of the field operations, but that is not easy to accomplish on the fly, in the field where it needs to happen, because of datum transformation issues, incorrect profiles in use, or incompatible map GCS occurences. Field staff cannot spend an hour at a check in point trying to figure out an inaccuracy problem. And we have documented where the accuracy bar in FM displays acceptable accuracy but then is not matched in the recorded GNSS metadata, causing more uncertainty. Ten years ago, maybe we could say that this was an evolving technology and not everything is worked out yet, but I'm not sure that still works after years of software and hardware improvements.
We don't have any magic solutions but would offer that if you need high accuracy results, plan on a lot of high-level support for that operation and have a strong tech support program to rely upon. Then be prepared to test their suggestions in the field, as they sometimes will not have the firsthand field experience that enables them to really understand your issue, nor the time to really listen. We welcome the opportunity to expose these topics in a wider forum of the mobile mapping data collection community.
Mike Mike
