Summary: Create a stand-a-lone or web-based app to convert DDF files or ASCII to a file Geodatabase. This one act would produce, for the world, a method for so many of us with long-standing relationships with Pathfinder Office, Positions and now Terra Office who simply need to convert thousands of highly complex to simple data dictionaries to file geodatabases.
Over a long history of Pathfinder Office / TerraSync, spanning decades.... there are tens of thousands of Data Dictionary files (DDF's), which contain all the elements for conversion to ESRI fGDB schema but for reasons below are being blocked for reasons of deprecation. Trimble invented the term Data Dictionary (DDF) and you all should be applauded for the simplicity and POWER of the DDF and the invention of the mighty Data Dictionary utility.
Trimble invented the gold standard for easy GIS feature collection (1990's), and may I suggest it was the premier reason PFO/TS flourished for so long, regardless of the Windows Mobile OS on devices. You gave us the power to create features, menus, default values, "float" attributes up or down, incredibly powerful photo integration, load large text file menu attribute items with a click of a button and copy across feature types (point to a line or a poly) that has NEVER been duplicated in the ESRI framework. I have challenged the best ESRI power users (using both Pro or FieldMap designer) many times to beat me in creation of a point/line/polygon. I'm outside collecting data in a fraction of the time, while the best template ever created is tweaked for a real-world scenario... Oh, you need another domain attribute value? Sure, hold on.... Sure, were not getting fancy smancy symbology, or relationships, but I'm suggesting, the majority of users don't need a basemap to collect data (Field Maps requirement), pop ups, tasks, over burdensome cloud-based Terra Office project creation processes TO GET THE JOB DONE!
Today:
- Pathfinder Office due to its lack of updates is no longer being allowed for installation on many high security systems (Federal Government), and the Data Dictionary App, cannot be loaded separately as a standalone. So when PFO is removed, so is the Data Dictionary utility
- ArcMap is, for many in the federal government being being pulled in early 2024 from all computers. Clearly, ESRI has long made it clear this day has arrived. Trimble Positions extension for ArcMap and its reader is therefore not available.
- TerraOffice for Arcmap (see#2 above) and TerraOffice extension for Pro requires login to TerraOffice, a non FEDRAMPED cloud which many agencies/bureuas cannot access due to security reasons.
- SAFE Software, FME use to have a DDF reader, but has long dropped the reader from its library.
We realize many exports from PFO workflows generated shapefiles, and we can load shapefiles into fGDB's, but the power of default values, menu lists etc are lost when loading data.
We know we can export an ASCII export from the Data Dictionary Utility, which contains the "schema", which could be an excellent workflow if ESRI could read that schema, but there is not one.
Could Trimble hear our pain out on the street to create a Data Dictionary Reader (app) that could provide a Reader/Writer capacity to generate features in a fGDB. Your relationship with ESRI is obviously very strong. Would this be something you could convince ESRI to create a "Create Feature and Domain" tool in Geoprocessing? Provide sample Python script to read either a DDF natively or even the ASCII output?
Attached is a sample of an ASCII out export from the DDF utility that has been used since 2015! We are losing our access to the Data Dictionary Editor. Please.
Thank you Trimble for all you have done in creating the gold standard for hi precision collection over the years and the awesome DDF!
Joel Cusick
