TILOS
  • 1.  Decimals in Gantt chart
    Posted 08-04-2023 08:43
    I would like to know how to suppress the decimals of the km field  in a Gantt chart. The data was imported using the "Début(distance)" field.
    You can see the problem I'm facing in the image below.
    The field 'Coût total' does not encounter the same issue as it was imported as a text field. The same approach cannot be applied to 'km' in order to ensure accurate sorting of data (from smallest to largest).
    The Gantt chart is organized as depicted in the image below.
    Thank you for your inputs.
    Best regards,
    Ivo
    Ivo Patrício
