Hello Jari,
i have same problem lot of local project to deleted and delete them one after one its very convenient.
we are in 2024 and they have no solution of them to select multiple project and delete them simply.
i use the version 1.21.0.518
Do you know if this always in backlog?
Thank you for your answer
Julien Merlet
Sent: 03-21-2023 09:12
Subject: Delete multiple projects
Hi Tobias,
I see, thanks for the insight. You're right, if the .IFC and .DWG file types are associated with Trimble Connect for Windows, then double clicking the model file in Windows Explorer opens TC Windows and automatically creates an offline project for the model.
One possible workaround is to instruct users to create one project for that purpose and add the files they want to view via the Add File button (or by drag & drop): https://docs.windows.connect.trimble.com/files-folders/adding-files-folders/adding-files-locally
I have recorded the improvement request into the application backlog. However, we don't yet have guidance when it might become available.
Jari
Jari Juntunen
Sent: 03-21-2023 07:54
Hi Jari,
In my Company the less tech-savy people tend to open Ifc and Dwg files by doubleclicking and thus end up with loads of local projects. For that the mass delete would be quite nice.
Regards,
Tobias
Tobias Steinhardt
Sent: 03-20-2023 07:28
Hello Yves,
Thank you for the feedback. May I ask further details behind your improvement request? For example, it would be interesting to know what is the main use case why you need so many local-only projects? Do you intend to make them available online at some point?
With regards,
Jari
Jari Juntunen
