WorksManager
Design Failed to Publish, multiple projects
  • 1.  Design Failed to Publish, multiple projects
    Posted 05-28-2026 10:41
      |   view attached
    Multiple projects failing to publish updates. says "Failed" immediately
    Taylor Weidner
    Tech Mgr
    Hoffman Bros, Inc
  • 2.  RE: Design Failed to Publish, multiple projects
    Posted 05-29-2026 05:14
    Same issue here. All of a sudden it just stopped working. It publishes fine but I get an error in WM that says the conversion didn't work. After hours of messing around and calls, I came to the conclusion it was a WM issue in TBC. I exported the same data through the Machine Job Site Design exporter and loaded the .svd and .svl files into WM on the web and everything seems to be fine.
    In TBC, I noticed that my project would turn red indicating a conflict in the project explorer anytime I tried to publish a design. Then I would go to the WorksManager Project and the error would clear. Super frustrating because I didn't change anything on my end. And now I have to worry that there is some other issue that I may not know about messing things up in the machines or something that will be catastrophic for my project.
    I guess it's comforting to know it's not just me.
    Sean McCarthy
  • 3.  RE: Design Failed to Publish, multiple projects
    Posted 05-29-2026 08:05
    Our customer are also having the same problem... support states that the TBC team updated the meat grinder between TBC proper and the WM and the error there is causing the design publish failures.
    Trimble, please test these updates and things BEFORE you release them to the production side, given the sad state of affairs with WorksManager, the TCC deprecation looming (maybe postpone it, eh?), the IBSS v2 pushback, etc. etc. you are skating on thin ice.  Many customers have expressed ideas of not paying their WM subscription invoices until the system is stable and fixed... I tend to agree with them.  You are flirting with contract breach, and your timing is absolutely horrible.
    Delton Searles
  • 4.  RE: Design Failed to Publish, multiple projects
    Posted 05-29-2026 09:13
    Same here. The issue seems resolved now after republishing the design
    Brad Greenwell
  • 5.  RE: Design Failed to Publish, multiple projects
    Posted 05-29-2026 14:22
    I'm getting the same error message.  Any updates on this?  I have crews going tomorrow they need this update.
    Jason Smyth
  • 6.  RE: Design Failed to Publish, multiple projects
    Posted 05-29-2026 17:40
    I was able to republish designs that were failed in WorksManager with success. I use the WorksManager tab in TBC. I just slightly changed the "failed" design so that WorksManager would see it as a new version  and give me the option to publish it again.
    Brad Greenwell
