Hi Jamie,
There is a switch in TMM which turns off the application of antenna height, see here:
For your users this should remain off for use with Field Maps. Also note that while setting 0 in height will usually yield the same results as 'off', changing the measurement method can impact this, so making sure the switch is off is the best way to be sure.
Regards,
Mark Kellaway
