Dear Aziz,
I have done some investigation and want to make sure I understand your problem correct.
Can you not download the project you created in Project Manager to your android device to work with it? or can you not download it from Project Manager?
If you can not download it via Project Manager and the status is set to in Progress, then this usually means that the Project was downloaded to an android device but has not been uploaded to the Project manager again yet.
If the work in the field is done and the Project is uploaded to the Cloud again the status should change to complete and a download via Project Manager should be possible.
Be carefull when assigning multiple users to a Project.
Keep the overview of what version of the project is in the cloud.
(If more then one user work on a project at the same time and upload it, it is possible that one overwrites the changes the other one has made if they didnt coordinate properly.)
Patrik
Patrik Stahlhut
