Hi!
Yes I have tried that before, but even if I change the color from layer manager it does not change the color on the map for the imported layers (called ebene on penmap, all black by default). With layer manager I can only change the color of the lines I add on penmap directly.
Patrice Ferron
Sent: 04-10-2024 01:22
Subject: Download shp in penmap with symbology.
Hi Étienne Guay,
the shp only contains information about geometry and data.
When you have created the data in a different GIS program, the easiest way would be to change the colours via the layer manager on the sidemenu of the project in Penmap.
Cheers
Patrik
Patrik Stahlhut
