Hi Mark,
I'll try to explain, but I don't want to box this request into any one radio, any one device since were talking almost the entire suite of Geodetic gear Trimble sells.
Receivers - R8, R10, R12's
Controllers - any Android (like the TSC5)
Radios - A TDL450 external radio, or NOT. Any of the receivers above tansmit VHF stand-alone - and is likely the most common scenario.
I have a Base station on control (or not), transmitting VHF corrections (RTK). A rover (any of the above) running on an Android controller suitable for ESRI Field Maps, could then lock onto that signal, pass it thru TMM (TMM in my mind is the middle ware that could simply engage with a VHF signal) and pass that corrected RTK signal into Field maps.
I hope this helps. What were trying to do is use Trimble Survey gear in a Field Maps scenario. Were spitting out mm precision data from a base, via VHF, and want to use that in our FM's. Currently all that expensive gear where internet, is unavailable in the field is wasted.
Joel Cusick
GIS Specialist
Region 11 - Alaska Regional Office
240 W. Fifth Ave.
Anchorage, AK 99501-2327
cell:907 280-9724 wk:907 644-3549
