Along with Matthew here,
TerraSync (Options Logging Interval) change capacity for Time, Distance is essential to migrate to TerraFlex, regardless if a schema is possible to set to an interval. This was the beauty of DDF/TerraSync and the dance we could do between them (bypassing what the NERD thought trails should be collected at, and then someone actually maps the trail). Two entirely different control levels, often ignored by industry. So we need to control levels.
But lets not forget the third and most powerful set of control a TerraSync running on a button based device (like the Geos). The PAUSE/RESUME function. here in NPS, we have mapped thousands of miles of trails, and they are all different in scale, and switchbacks etc. We map our trails at 5 meter distance intervals, but at a moments notice, that switchback up ahead needs 5 vertices to accurately portray its alignment. Pause/Resume,Pause/Resume,Pause/Resume,Pause/Resume,Pause/Resume, will create the needed vertices for its ground representations. No one else on the planet is doing this (exception is a new Garmin with a pause/resume on an activity). This third component Pause/Resume, function is mandatory in my mind. This could be a "pop up" window and a pause icon / Green Go icon available during line and Poly construction to allow this to occur. Were not mapping just points. GIS persons, unlike surveyors, construct lines and polys every day. Help use with a GIS centric software that can get close to TerraSync's long evolutionary path, and you can help us. Put TerraSync running on a Geo7x next to TerraFlex on a phone. You'll get the picture!
Thanks for the opportunity to enhance TerraFlex.
Joel Cusick
Sent: 05-12-2022 06:53
Subject: Enhancement Requests for TerraFlex
Hello Hamish and thank you for your reply.
I am happy to hear that Trimble is working towards adding the aforementioned features to TerraFlex. I will continue to monitor the Community with great anticipation!
To answer your question, I adjust the logging settings within TerraSync and is dependent upon the type of on the ground feature I am collecting, terrain I am working within, and mode of transport.
I hope this helps!
Matthew Stersic
Sent: 05-12-2022 02:58
Hi Matthew,
Thank you for your feedback here.
We are continuing to enhance the feature set of TerraFlex to fill the gaps between it and TerraSync. Items like customized logging rate, image watermarking, and improvements to navigation are high on our priority list.
On the logging interval specifically - did you have the logging settings for each Feature Type configured in your Data Dictionary File, or did you configure it within the Logging Settings in TerraSync?
Thanks
Hamish
Hamish MacMillan
