In the past we've typically used our R10 as a rover with an RTX correction service. However, I'm attempting to use the R10 as a base for PPK correction of UAV data. I'm able to setup logging and get the t02 file, but when I attempt to bring the t02 into the utility I receive an error message which prevents loading. Any ideas what on what may be causing this error as well as potential solutions?
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.NullReferenceException: Object reference not set to an instance of an object.
at trimble.rinex.CfileConversionInfo.get_antennaType()
Thanks!
Jake Slyder
