  • 1.  Feature Library Issues
    Posted 12-25-2024 17:51
    I have created a Feature Library using Feature Definition Manager for use in a Trimble TSC5 Data Collector. I have attached a few pictures of how I have my Feature Library set up in the definition manager. Once I collect data using this library in the field we then plan to export the data to a dxf to be used in GIS. However when this happens there is duplicate data in the fields which is causing an issue in GIS with data management. Is there a way to eliminate the duplication of information?  Or should I be setting up my library differently?
    Kelly Demeny
