Let me clarify: when using clip plane tool object that are cut appear holow:
Instead I would like object to appear solid, just like in Sketchup where you can turn on 'Section Fill'. Ideally "section fill" would inherit color/material of parent.
Jure Judež - Celovito
Sent: 02-06-2024 23:43
Subject: Feature request: Section Fill
Thanks Jure for clarifying. In the Trimble Connect for Browser 3D Viewer, it is possible to move the clip planes (with the scissor icon) which help to have the cut sections back.
Could you please check if that helps your use case (Reference - Documentation).
Darshan Rajaram Kamat
Sent: 02-06-2024 23:37
Yes, sorry I was referring to clip planes...
Sent: 02-06-2024 20:47
Hi Jure,
Could you please confirm if you are referring to clip planes (by section cuts) in the Trimble Connect Browser 3D Viewer ? If not, could you please clarify what is section cuts ?
