Field Maps not displaying correct accuracy when using Trimble Mobile Manager and DA1
  • 1.  Field Maps not displaying correct accuracy when using Trimble Mobile Manager and DA1
    Posted 07-26-2024 05:59
    Hi folks, some help on this would be really appreciated.
    I am using the DA1 antenna with a Catalyst 60cm subscription. I am using Esri's Field Maps app to record data and the Trimble Mobile Manager (TMM) to utilise the DA1. TMM is working perfectly well and providing the accuracy I need (60cm). However, when using Field Maps, the accuracy in field maps does not reflect the accuracy being achieved by the DA1 and is instead providing accuracies as low as 2-3m. This problem has only recently started- until recently, Field Maps was displaying the accuracy of the TMM. I have no idea why this problem has suddenly started.
    I have utilised developer setting in my phone in order to use TMM as the mock location provider, and the Field Maps app is using the 'integrated' location provider- so in theory, TMM is providing the location.
    I did notice that sometimes when opening Field Maps, a message appears stating "Incompatible Location Profile". Could this have anything to do with the issues I am facing?
    Thanks in advance for any advice!
    Scarlet Maguire
  • 2.  RE: Field Maps not displaying correct accuracy when using Trimble Mobile Manager and DA1
    Posted 04-29-2025 06:22
    This is also an issue for us. Were you able to figure out the problem?
    Maya Rao
  • 3.  RE: Field Maps not displaying correct accuracy when using Trimble Mobile Manager and DA1
    Posted 04-29-2025 07:04
    Hi, I don't remember finding a solution per se, but I found that after upgrading from the DA1 to the DA2 the problem seemed to solve itself. Sorry I can't be more help!
    Scarlet Maguire
  • 4.  RE: Field Maps not displaying correct accuracy when using Trimble Mobile Manager and DA1
    This is also an issue for us. Were you able to find a solution?
    Maya Rao
