Failing to power on sounds like there's some hardware problem with the unit. Try an OS reload if you can, but I don't have much hope that it will fix the behaviour.
Norman Smart
Sent: 03-26-2024 05:19
Subject: Geo7x Handheld Won't Power On Until I Remove and Reinstall The Battery
The condition I described was how it was brought to me. At the moment, it will not even power on. Every now and then I can get it on. It does not matter which battery or charger I am using. If I can get it to power back on I can try your suggestion. Thanks for taking to the time to share.
David Hames
Sent: 03-25-2024 13:49
I don't remember ever seeing this problem with Geo 7x, and I've done a lot of work with Geo 7x (but not recently).
One of the guys who knows Windows Embedded suggests that it could be getting stuck somewhere while shutting down or when resuming from shut down, starting up after shutting down is not quite the same as starting after the battery has been removed.
Re-loading the OS would probably fix the problem - OS 6.7.18 is available on the Trimble MCS downloads page - but then you'd have to reload all your applications which might be challenging!
Norman Smart
