Hi Kara,
I think these are simply manufacturing date codes on the cables with the second number being the year. I have cables here from /15 and my new one is also /21.
The firmware should be fine with any good cable.
Other than the GNSS signals, the cable also supplies some power from the Geo7X up to the antenna and that's what your Geo7x is complaining about. So you may have a leakage/short problem with the new cable/connectors, or possibly a legacy issue in the devices resulting from the previous cable.
There are a couple of basic checks you could do to help isolate:
1. If you still have the old cable, reconnect it. If it all works without the message, then the Geo7X & Zephyr themselves are OK and confirms the issue is with the new cable.
2. Get the new cable checked with a multimeter if you can get access to one. There should be continuity between the center pins at either end, and also between the outsides of the connectors at either end. And there should no continuity at all between the center pins and the outside of the connector.
As a guide, my meter here on a good cable shows less than 1 ohm resistance between the center pins, and also between the outside shields. And it shows no reading whatsoever (>40 MΩ) between the center pin and outside connector.
John Winkler
