Wayne,
What is your software workflow. Because the TDC650 is android based, its not compatible with TerraSync. The Geo7x, based on WM can run TerraFlex or Arcpad, but not Access/or TerraFlex/ESRI mobile software.
As for yield, precision and accuracy, no comparison between the devices Chipset and burnt in FW (e.g. Floodlight on geo7x), nor the integration factor (rangefinder). Combine the Geo7x with differential correction (in deprecated PFO) or Positions (ArcMap only), there is no question that user community is on its own.
USFS has some limited testing between Catalyst, TDC600 and Geo7x, confirming the errors on the TDC600 being much higher under canopy than the other two.Harder to tease out the Geo7x vs Catalyst though. USFS has done a wonderful job assisting the user community. Huge shoutout to the agency with these non biased evaluations. https://www.fs.usda.gov/database/gps/mtdcrept/accuracy/index.htm
Joel Cusick
Sent: 09-19-2023 06:08
Subject: Geo7x vs TDC 650
Hi David,
You can integrate an external rangefinder with the TerraFlex software in combination with a DA2 who uses the ProPoint technology from the high end model R12i.
Kind regards,
Denis Snauwaert
Application Engineer AllTerra-BeLux
Denis Snauwaert
Sent: 09-18-2023 05:11
I see what you are saying Wayne. We agree, 100%. I am curious about the DA2 incase they make these 7xs inoperable. We are really hoping someone comes out with a device that is truly competitive with the 7x very soon. If we have to buy a device like a 650, we would rather just bring our cell phones and not buy the 650s because we can still utilize a rangefinder, even though it is mounted to a pole and we are less invested with Trimble. We would be more willing to consider the 650s if they have a laser that is internal or mounted external like the 7x.
David Hames
Sent: 09-18-2023 04:30
Thanks for posting your message regarding the 7x. The DA2 works great and doesn't have issues like the 650. The problem with that is you have to connect a battery and connect to a device. It is not the all in one like the 7x and 650.
Wayne Randall
Sent: 09-15-2023 08:11
We have 15 Geo 7x handhelds with the external lasers mounted under the receiver and have used Trimble units for 20+ years. We have always loved the accuracy, simplicity and versatility the 7x offers. For a few years now, we keep getting encouraged to jump in and replace what we have. We are concerned with buying the new units that are recommended because of the need of multiple components that need to be taken into the field instead of a single device and now we see the ability to collect accurate points in canopy may be an issue.
Our team of data collectors use on a regular bases the range finders to collect locations and store attributes on many features in our line of work. Some are on sidewalks collecting points on features that are hard to access or just not safe to stand over or access. Some data collectors are in boats collecting points on features on land. Some of our collectors even collect data on estimates of how tall a trees are by using the laser. When it comes to collecting consistently accurate points, the 7x is perfect for that even with the tree canopy using the floodlight technology. You cannot beat the ruggedness of the 7x. We do not get them wet. I am not sure how well they will stand up to that but we have had them dropped on asphalt and still work fine.
We are hoping soon that a company can offer a unit that is a true all in one and comparable with the 7x (including a laser that is integrated or mounted under the receiver) on accuracy and performance level. It is clear to me there is a need still for a unit that can perform and compete with the Geo 7x handheld.
I wonder if the DA2 has issues collecting as accurate and consistent positions as the 7x under canopy?
David Hames
