Compass calibration will only affect positions which are captured using Distance / Bearing Offset workflows (typically using the Laser Rangefinder accessory), compass calibration will not make any difference to GNSS positions! And even if your compass calibration was faulty and you did use Distance / Bearing offset, the worst error this could give (assuming the compass bearing is wrong by 180°) is 2 times the rangefinder distance, i.e. a few hundred metres at most.
Forget about compass calibration, a 6 mile error is likely to be reference frames / coordinate systems or similar, as suggested by Joel and by John
Norman Smart
Sent: 12-18-2023 13:40
Subject: GNNS position on handheld does not correspond to position in field.
I have tried both calibrations. Now the compass disturbance is in good standing. However, not sure how to tell if the calibration helped make the GNSS position more accurate as I'm not on the project site anymore. Which leads me to my next question. How can I tell if the files are working and the Geo7x is accurate without being on-site to see if the GNSS position is on the boundary background file. In other words, is there a way to test the files at the office before heading to site?
Patrick Pegnato
Sent: 12-12-2023 05:55
I am just curious, have you tried to do a fast or full calibration on the unit?
David Hames
