Thank you for the answer. I do run into a problem when importing it.
a) When using Import GIS/CAD data i do get the layers that i have added in the google earth but i can not see it in Quantm.
b) Or when i use import alignment instead the program crashes.
Thank you in advance.
Adam Terkenberg
Sent: 11-30-2022 06:20
Subject: Google earth file to Quantm
Hello Adam,
You can export both lines, polygons and alignments from Google Earth Pro in KMZ/KML file format and import it to Quantm using "import GIS/CAD data" or "import alignment".
Cecilie Erland
