Right...the way I did that was download several times and upload those to get copies
Sent: 09-08-2023 07:35
Subject: Re: How do I copy a file?
I think for that Save as in DWG editor would work easily
Best Regards,
T Laine
@Tero Laine: Sounds promising, but unfortunately the "saveas" command has no effect in the Trimble Connect CAD editor.
Steffen Blome
Sent: 09-08-2023 07:22
Best Regards,
T Laine
Sent: 09-06-2023 23:27
One use case where copying files would be very handy is, when you have an DWG file with several views/frames and you want to split those views/frames to one DWG file each. If you had 4 views in the source file, you could just copy it four times, open each copy in the CAD editor, delete the frames you don't need and save the file.
Steffen Blome
Sent: 07-04-2023 08:07
Hi Ricci,
Just curious, what kind of data would you want to copy inside a project? Once copied, doesn't that make room for errors?
Jack de Moel
Sent: 06-30-2023 14:24
Is this feature ever going to be available? I get the request daily as more and more users join Trimble Connect.
Ricci Stevens
Sent: 11-08-2019 15:50
Unfortunately, there is no option to copy or duplicate a file in Trimble Connect. I usually download the file I want to duplicate, rename it, then upload the renamed file back into Trimble Connect. It's a hassle, but much faster than starting a new file from scratch.
