Importing point data in ascii text into a project
  • 1.  Importing point data in ascii text into a project
    Posted 04-29-2024 10:14
    I am new to Trimble Connect and work a lot with data as text with files as .csv. Is it possible to import this data directly into the project in the local coordinate system (which is supported by Terraflex) without having to go through the tedious process of converting it to d.dddddddd, loading it into Google Earth, converting and saving it as a .kmz file, importing it into Trimble Connect and have the coordinates report in d.ddddd instead of the local coordinate system that the project is set for? Yawn! This is really a painful process!!!
    David Grant
