Issue with the New Version of the File Uploader
  • 1.  Issue with the New Version of the File Uploader
    Posted 05-08-2025 08:08
    Yesterday, I downloaded the new update for the File Uploader for Revit, but now it seems to lack half of the configuration functions, including one of the most important ones for me, which is the ability to convert RVT files to TRB. Some RVT files are so large that they literally take days to upload completely, but with TRB, it's reduced to a few hours. Does anyone know if this function will be reincorporated at some point?
    Camilo Martinez Guevara
  • 2.  RE: Issue with the New Version of the File Uploader
    Posted 05-09-2025 07:25
    I never could import Revit files into Trimble Connect. I once left it for a few days and it was still churning away.
    But the same BIM model in Navisworks format would import in under 15 min.
    Using Revit , export to Navisworks. Trimble Connect imports Navisworks files nicely.
    Sent from Outlook for iOS
  • 3.  RE: Issue with the New Version of the File Uploader
    Posted 05-09-2025 10:14
    If the Navisworks files load faster, but they skip all the information I need to filter and also the custom parameters. But thank you.
  • 4.  RE: Issue with the New Version of the File Uploader
    Posted 05-10-2025 08:11
    Let me get this straight.
    So Revit can export to Trimble TRB format but Trimble Connect can't import Revit files.
    Or if Trimble Connect tries to import then it takes a ferry long time (like days)
    I stopped the import after 3 days because I taught something was wrong.
    Should I just leave it for like a week to see if the import is successful.
