Does the device name that is set inside SCS900 match the folder name on TCC?
Each device has a folder with its name on TCC
Once it's set in SCS900 you can't just change it. Close SCS900 and find the allsites.xml on your handheld in the SCS900 folder.
Either delete it and start SCS900, in that case you'll have to set all other settings again as well.
Or edit it in a text editor.
I believe in older versions those TCC settings were in the site.xml.
Sent: 12-08-2022 09:29
Subject: Juno T41 handheld
Also I tried setting up the Juno to connect to TCC which it seems to connect but does not retrieve files. Anyone use this with TCC?
Tom Silicato
Corrado Construction
New Castle, Delaware
tsilicato@corrado.com
www.corradoconstruction.com
Sent: 12-07-2022 07:33
When I connect my Juno T41 to my computer a windows 10 system, windows mobile opens up automatically and i can explore the files there and add sites.
Ben Brown
