YES!
And do not update from any template field during import in this case.
Thorsten
Thorsten Jourdan-Balthasar
Sent: 10-12-2023 01:40
Subject: Large data changes
Hi Thorsten,
Thank you for the feedback. I found the following to be the minimum fields for export / import.
| Activity IDentifier | Parent ID | Sub-Project ID | | Name | | Activity template name | Sub-Project ID |
Stuart Jones
Sent: 10-12-2023 01:31
Hi Stuart,
yes, in fact the import behaviour has slightly changed during recent updates (11.1Mr3 and 11.1 MR4) .This is connected to the enhanced data assignment from the template coming in this versions.
1. template reallocation: Please consider this as a bug. It is already known and addressed. Workaround: Add the Template to the Export fields in Step 1. During import do not assigne any fields from template.
2. parent data allocation: As to my knowledge this is no bug and has been ever since Version 10. Same solution: Add the Parent-Id to the Export in Step1. Then also import the Parent ID.
3. sub-project allocation: As to my knowledge this is no bug and has been ever since Version 10. Same solution: Add the Sub-project-Id to the Export in Step1. Then also import the sub-project-ID. (This is happening if you have more than one subproject only).
Good Luck.
Thorsten
