Hi Tijs,
I Fully agree. It would be a huge benefit if this is an Trimble Feature in the near future. Even to do some data formatting within these files, like organizer and properties data.
For now, if you need to work with the TrimBIM file, you can import this TrimbBIM file to SketchUP and then export it to IFC. The propertysets, properties and values will be a problem though..
Kind regards
Stefan Kauffeld
Sent: 12-03-2024 01:01
Subject: Merge multiple files
Hi Marko
Thanks for your reply!
I know this is possible as a TrimBim file, but this is not an interchangeable format for customers using software other than Trimble Connect.
It is a bit silly to rely on other untrusted free sites or competitors of Trimble for this functionality, rather than this trusted platform.
Hopefully this is a feature that is on the roadmap!
Or is there a workaround to import TrimBim into other softwares?
Thanks.
Tijs Van de Moortel
Sent: 12-03-2024 00:48
Hi Tijs,
This is not fully possible, but you can combine two models (or more) and then export that as TrimBim file.
You can do this in Trimble Connect for Windows, see documentation here. https://docs.windows.connect.trimble.com/models/export-as-trimbim
Hopefully this helps.
Best regards,
Marko Myllymaa
