Hi, good morning.
For some of my Trimble Connect models, the 'Dimension' section is missing from the 'view properties panel'. As 'Calculated Geometry Values' section calculates all the geometry planes of an element (floor/wall etc) when showing the area for that element, the 'Dimension' section seems to provide accurate area for a surface itself. However, as mentioned above, few of the models do not have the 'Dimension' section whereas other models do (please see the attached image below). Does anyone know what is the reason behind this and if something can be done to add the 'Dimension' section to the models that do not have it?
Any information/suggestion on this is much appreciated.
Thank you.
Best regards,
Nishat
Nishat Aive
