Hi Ben
Please see this video: 20240514 214107 HoloLens
and compare it with the other helmet:
Another hamlet can anchor down the model.
Hexin(Johnson) Zhang
Sent: 05-20-2024 17:50
Subject: Model moves with the view after QR code aligned, and can't logout of Trimble Connect MR account
Hi Hexin,
Thanks for sharing the video. It looks like you are seeing a little bit of the movement and some minor drift as you move away, but it still seems to stay lined up pretty well with the pole? Certainly you can expect some amount of drift when working with the XR10.
The second link you shared seems to be the same as your first, so I didn't see the issue you had with the login. I've sent you an email and put you in touch with our support team to follow up on this one.
Ben Broad
