Hello
In the user guid of Trimble Connect it is stated that 'Uploading a new revision of a file with a different name is not supported'.
It would however be interesting if you can indicate that a file is an update/revision of another file with a different name.
Is there a 'work-around' or even better, has Trimble plans in incorporating this in a new release?
Wim Moerman
