TILOS
New TILOS Version
  • 1.  New TILOS Version
    Posted 12-28-2023 08:05
    Hi TILOS,
    Will there be a new version release?
    Stuart
    Stuart Jones
  • 2.  RE: New TILOS Version
    Posted 01-02-2024 11:53
    Hi Stuart,
    The Tilos team hopes to release the next maintenance version within 3 - 6 months (first half of 2024). If you have a pressing need, feel free to reply here and I will make sure it's added to the developement backlog.
    David
    David Kosakowski
  • 3.  RE: New TILOS Version
    Posted 01-03-2024 14:39
    I am a veteran Project Manager of over 40 years, and the word "help" is not in my professional vocabulary, since it is meaningless. I hope to win the lottery, but it makes no difference.
    Is there a real plan for the new Tilos version?. There is a great piece of software for planning projects. I suggest Trimble use it themselves to come up with a clearer answer to the question. When will the new Tilos  be released?
  • 4.  RE: New TILOS Version
    Posted 01-03-2024 15:17
    Edited by David Kosakowski 01-03-2024 19:28
    I appreciate your point, Thomas, but there are strict revenue recognition policies that prohibit announcing plans/dates before the fiscal quarter in which a product is to be released.
    David
    David Kosakowski
  • 5.  RE: New TILOS Version
    Posted 01-03-2024 16:53
    excuse accepted would not be on my projects
  • 6.  RE: New TILOS Version
    Posted 01-09-2024 02:04
    Hi David,
    Thank you for the indication.
    There is a number of issues with the last update 11.4. Below are the main issues.
    Transferring information from TILOLS to P6 is my biggest issue.
    - This appears to be dependent on the P6 Database version (older versions work). New database versions, import is not possible.
    With the TILOS P6 XML export into  P6, links are often missing, when importing resources and global calendars import to P6 crashes regardless of import profiles and database version.
    Import from P6 to TILOS renames calendars as imported even when they are the same calendar (no changes), it is not possible to remove the "import" description. Unless you create a new calendar. This creates problems when exporting etc.
    EXCEL updates, issues exist. templates, layers renamed for no logical reason.
    Import / Export Templates names in pull down list are often listed with the same name. Even though they contain different details.
    Purging of data doesn't function that well, hidden data remains and is difficult to delete. Very difficult to reduce file sizes.
    Stuart
    Stuart Jones
  • 7.  RE: New TILOS Version
    Posted 01-09-2024 09:35
    Stuart, thank you for the detailed bug description. I added it to the development backlog as issue TIL-1832.
    David Kosakowski
  • 8.  RE: New TILOS Version
    Posted 10-14-2024 03:40
    Hi David,
    Any news on when a new update can be expected?
    Stuart
    Stuart Jones
  • 9.  RE: New TILOS Version
    Posted 10-14-2024 13:39
    Hi Stuart,
    I apologize for the quiet this year about the next Tilos release. An internal restructuring precluded an update, but we will have clarity on the next release by the end of the year. Sorry for the inconvenience.
    David
    David Kosakowski
  • 10.  RE: New TILOS Version
    Posted 10-15-2024 22:00
    Thanks for the feedback.
    Stuart Jones
  • 11.  RE: New TILOS Version
    Posted 12-31-2024 11:14
    I've run into a similar issue: when I try to use the newer versions of the P6 database, importing just doesn't seem to work. While digging into this (I found useful material at https://andersenlab.com/industries/financial-services/defi-development-services on the topic of systems integration), I noticed that TILOS and P6 use different formats for data exchange. TILOS might not be able to handle some of the XML formats that P6 uses, which leads to some errors when trying to move data back and forth. For instance, P6 version 6.2 introduced a new XML format that older TILOS versions might not support, and that's where the compatibility headaches come in.
    Oh, and with EXCEL, I've noticed that after updates, some layers and templates get renamed, making it tough to find the data I need. I really hope these bugs get sorted out in the next updates because they seriously mess with productivity.
    Dan Mistry
  • 12.  RE: New TILOS Version
    Posted 12-31-2024 19:16
    What did TILOS support say to all of this.Did they fix it ?
  • 13.  RE: New TILOS Version
    Posted 01-03-2025 01:26
    TILOS have mentioned they are unaware of the issues and they will not be considered in the next update.
    I am of the view that TILOS wishes to become obsolete and we can simply use cheaper more efficient printing software.
    We have had to build a conversion software to cleanup the xml for use in P6.
    Stuart Jones
  • 14.  RE: New TILOS Version
    Posted 22 hours ago
    Hello David - can you confirm this BuildingPoint Australia article that as of March 2026, Trimble is no longer supporting TILOS?  I've tried to find additional documentation but this is the only article that keeps coming up.  Many thanks, Patrick
    https://help.buildingpoint.com.au/hc/en-au/articles/55527556493849--Important-Announcement-Tilos-Entering-End-of-Maintenance-on-1-March-2026
    Patrick Russo
  • 15.  RE: New TILOS Version
    Posted 21 hours ago
    Hi Patrick,
    Yes, I have confiirmed that the BuildingPoint announcement is correct. Thank you for bringing it to my attention. I will post a similar announcement on the Tilos Community home page.
    Regards,
    David
    David Kosakowski
  • 16.  RE: New TILOS Version
    Posted 14 hours ago
    Hi Patrick,
    As per the announcement from Building Point, if you are in Australia or New Zealand please reach out to us at Delta Solutions to discuss the next generation which is called Tilos 360 as well as other options moving forward.
    Kind Regards,
    Dave Crosby.
    Dave Crosby
