Hi Corinne,
DA2 will work well with the Nomad 5, and with Catalyst you'll be able to choose your accuracy level, including using Catalyst On Demand to utilise cm level precision by the hour. My only concern with your suggested use is attachment of the Nomad 5 to the Catalyst handle. Attachment of the mobile device to the Catalyst Handle is achieved through the use of a stick on magnetic plate, and the positioning of the battery on Nomad 5 will mean this won't be possible (I wouldn't recommend attaching it via the battery).
Another potential solution for you if you want handheld use is to use a backpack with a short pole attached. The connection to the DA2 is Bluetooth so you could have the Nomad 5 in your hand and the DA2 on the backpack. Obviously you'd need to take the position of the receiver into account when collecting your data.
Note that DA2 will also work with any 'off the shelf' Android or iOS mobile device, and any device with a flat back can be attached to the Catalyst Handle (I'd recommend using a case as the glue on the plate is pretty strong!).
Regards,
Mark Kellaway
