thanks for sharing this information and picture from the device.
I assume that you are using Trimble Corrections hub as an correction service.
The blue colored satellite number indicates that you get a RTX solution.
Typically an RTX solution takes longer to get to a fixed position, even if the antenna tracks 21 satellites.
Please check the position status: Tab&hold on the GNSS button --> GNSS Position
Please get in touch with your local Trimble dealer.
He should be able to tell you what accuracy you can expect at your location and how long it typically takes to get it.
He can also check if there should be a VRS service available in your region.
Thanks
Thomas
Thomas Schucker
