Sent: 04-05-2023 05:49
Subject: Offsetting points / Throwing points.
Just to lend some weight here, what Casey is asking for is a feature that my group is looking for as well. We are currently digitizing the points as a workaround because we don't have our old units anymore, but this solution isn't very helpful when we are actually interested in obtaining sub-meter accuracy. This is a glaring flaw with this "new and improved" software.
Sarah
Sarah Hirsch
Sent: 04-05-2023 05:41
Still no response, I will try and send here since it has been 16 days since I have last heard and sent a follow up
No I need to offset, I have already ran into multiple problems without having this feature. I have had to haul the old unit and go back out to site to do this. So for the new units not to have this feature is an embarrassment. I have wasted time and money because this feature is not on your "new and improved units". This needs to fixed ASAP. There are multiple people on here that are having the same problem. I was promised the same and new features and now have to bring the old and new unit into the field with me because your new units cannot do the same thing as the old one.
Casey Quade
Sent: 03-19-2023 20:35
Hi Casey,
Apologies for the delay in my response.
Thanks for your input above, while we have not yet made a decision to support manual entry of point offset values it is helpful to understand your workflow and accuracy expectations.
As an alternative I am interested in whether you would consider digitizing a point on the map?
Thanks,
Hamish MacMillan
TerraFlex Product Manager
Sent: 03-14-2023 06:51
Still waiting to hear an answer from all of you. Any update?
Casey Quade
Sent: 01-29-2023 14:16
Hi Everyone,
Thank you for the discussion and feedback on offsets.
For those who are/were using offsets in TerraSync and manually entering the Distance and/or Bearing values - can you describe what method you were using to measure those values? And also what your expectations are for the positional accuracy of those features? i.e. if your GNSS accuracy was 10cm/4in and you manually measure and enter the offset value, how accurate would you expect the offset feature position to be
Thanks,
Hamish
Hamish MacMillan
