On demand subscription is good but very expensive
  • 1.  On demand subscription is good but very expensive
    Posted 10-10-2022 02:57
    in the foreground: I have catalyst DA2 which i use with third party app (QField) for surveying or other field work. I love it, precise and works good in the field. But. I hate the on demand subscription (10 hour cm precision).
    field example: I started 1 hour session from my pool. I measured cca.5-10 minutes in one place. Approach other field needs 55 minutes by car the started 1 hour session was ended while I got there. Start a new session...see above, in the third place start the third session...etc.
    I worked 30 minutes (or less) I've paid 3 hour.
    I disconnect the antenna from the TMM, but the counter continues to work. (I did not dare exit from TMM because I supposed I will see a "start new session" message...probably yes. The same cup of tea.
    Am I wrong or are there any solution to work with higher cost effectiveness?
    Why is not exist such counter based on minutes of the using? The wroted situation is lifelike...the costumer don't like the the next sentences: "we need hurry up because soon end of the session."
    Thanks for reply,
    Bela
    (that's why I use on demand subscription because I've casual works nowdays)
    Béla Motkó
  • 2.  RE: On demand subscription is good but very expensive
    Posted 10-10-2022 14:29
    Thank you for your feedback, Béla.
    By way of explanation to yourself and other readers, the Catalyst On Demand payment model works as follows...
    You pre-purchase 1-hour licenses in a pack of 10 or more. You can pre-purchase as many hours as you choose, and these fill your account (a bit like a pool), and you can consume the licenses at any time over a 1 year time period. Currently the pricing for the On Demand license is roughly US$11/hour, and this will vary based on your location (tax and currency etc.). Contact your local Trimble distribution agent for details of pricing in your country...
    Each "On Demand hour" is effectively a 1 hour access token. The license starts when requested in the field, and ends 60 minutes from that moment. If you need a longer duration, you can load multiple licenses at once and they will extend the duration of your session. As you noted, the hours can not be 'paused' (for example,  you can't use 15 minutes of a license, then pause, then use  further 45 minutes the next day). This is because the license is not for a discrete quantity of minutes of use - it is a license that starts at a specific time, and ends at a specific time.
    This license model is designed for occasional use and is most economic to those using the tools for 1-2 hours per day, each workday (i.e. < 9 hours per week, or <30 hours per month). If your usage is NOT easily predictable then Catalyst On Demand is a great tool for this. If your estimated usage is higher than this, it probably makes more sense for you to purchase either a monthly unlimited use, or yearly unlimited use Catalyst subscription.
    The more 1x hour licenses purchased in a block, the lower the price (for example 100x and 1,000x blocks of hours are available at a reduced cost per hour). Each hour has a 1-year usage window.
    Other options are available to you if your workflow does not demand 1 cm performance. Catalyst On Demand is only available in the "CAT 1" (1 cm) precision level, but if you are able to work with lower precisions, the Catalyst monthly and annual subscription models are available in CAT-10 (10 cm), CAT-30 (30 cm), and CAT-60 (60 cm) modes also.
    Gareth Gibson
  • 3.  RE: On demand subscription is good but very expensive
    Posted 09-13-2023 08:39
    Dear Gareth,
    Yesterday i actvated catalyst 30 subscription and beside this i've 1 hour on-demand too. Tomorow i need for catalyst 30 but i can not change to this. What is the problem?I thought that I can make decision which catalyst levels i would like to use it. The catalyst 30 is activated I checked in TMM, naturally.
    Thanks for Your help, Bela
    Béla Motkó
  • 4.  RE: On demand subscription is good but very expensive
    Posted 09-13-2023 16:16
    Greetings Béla,
    You should be able to use your Catalyst 30 license so long as it is current, and so long as you don't also have a current Catalyst 1 On Demand license active. Catalyst's license logic is that it will always give you the best possible performance based on the current active licenses associated to the user.
    The only reason that you would not get CAT-30 performance is if:
    1) You don't have a current CAT-30 license assigned to your username
    2) You do have a current CAT-30 license, but you also simultaneously have a current CAT-1 or CAT-10 assigned to you from another account (or you still have an active On Demand session running).
    Here below, you can see my TMM screen, where I have a Catalyst 30 subscription and I am also a member of my on On Demand pool. My current license is shown in the Subscription tile, and as you can see this is Catalyst 30.
    When I start an On Demand session, I am assigned a 1 hour license to Catalyst 1. This overrides my Catalyst 30 license for the next hour, after that time it will automatically revert back to my default Catalyst 30 license.
    Gareth Gibson
  • 5.  RE: On demand subscription is good but very expensive
    Posted 09-13-2023 21:36
    Thank You Gareth! It is clear. No need to start (to tap) the catalyst 30 just the on-demand hour if it needed.
    Wish you the Best, Bela
    Béla Motkó
  • 6.  RE: On demand subscription is good but very expensive
    Posted 11-21-2023 20:09
    Gareth,
    I have a question regarding Catalyst on Demand offline use. My field crews are typically working offline in a remote area and don't have access to internet or cellular signal.  In your message above you state the following: "If you need a longer duration, you can load multiple licenses at once and they will extend the duration of your session. " How does this work offline.  Do you end up downloading four (4) individual 1-hour licenses that can be consumed as separate 1-hour session as needed throughout the day or is it a 4-hour license block that starts counting down as soon as you start the session?  I'm evaluating Catalyst on Demand for our units, but we constantly work at remote sites so any insight that you can provide would be helpful.
    Luis Mercado
  • 7.  RE: On demand subscription is good but very expensive
    Posted 11-21-2023 21:11
    Hi Luis,
    The On Demand tool in the Trimble Mobile Manager (TMM) app permits a user to claim a series of hours by extending the current license - but these are not inidivudal 1-hour licenses. The way our license system works is that the user has a single license, and the expiry date/time is extended a further hour with each additional hour claimed. It is not possible to pause or break apart the individual hours into separate licenses.
    For your use case, I would suggest drawing down a number of hours at a time in the morning prior to heading into the field (while you still have internet access), or alternatively a monthly or annual subscription - which can be operated in an offline mode for up to 30 days at a time.
    Gareth Gibson
  • 8.  RE: On demand subscription is good but very expensive
    Posted 11-13-2023 15:50
    Dear Trimble,
      It would be nice in the next version of Catalyst to be able to "pause" the cm level say for up to 30 minutes while the user
    is traveling a long distance between points. Just a suggestion.
    Vince Cavanaugh
  • 9.  RE: On demand subscription is good but very expensive
    Posted 02-24-2025 13:49
    I agree; it's unfortunate that the survey can't be paused at any time or that the time slots aren't shorter - 15 minutes would be much more reasonable. I face the same issue - I use GPS occasionally, but when I do, I often have to travel 20–30 minutes between survey locations, making this solution quite costly. As long as Trimble lacks serious competition, they likely won't adjust their service to meet customer expectations. Imagine being charged for a full hour every time you make a phone call...
    I'd also like more flexibility with the Catalyst on-demand purchase method. Having to go through a local reseller isn't ideal, especially when you need to use it on weekends. An online store with immediate top-up options would be the best solution.
    Tomasz Szabon
  • 10.  RE: On demand subscription is good but very expensive
    Posted 02-24-2025 14:06
    Agreed on all points!
    I'm a hobby user, mostly getting by with 60cm accuracy, and use 1cm on demand rather sparingly. A bit more flexibility might draw in some of my friends, who regard GNSS as an expensive solution, which it still is ....
    And having to go via a dealer just to top up, is rather 20th Century....
    Rob
  • 11.  RE: On demand subscription is good but very expensive
    Posted 02-24-2025 15:12
    I don't need trimble catalyst anymore:-( Sorry but there is a more flexible and cheaper alternative on the market. I use it instead of catalyst with inland rtk subscription (e.g real time minute based counting). Catalyst flew away, but it's a shame because it was well aimed.
  • 12.  RE: On demand subscription is good but very expensive
    Posted 02-24-2025 15:48
    Good point. These apparently don't work with the Trimble DA2 receiver though (I tried one RTK service).
    Rob
  • 13.  RE: On demand subscription is good but very expensive
    Posted 02-25-2025 08:28
    To be fair, Catalyst works really well - it's fast, accurate, reliable and available in many locations around the world - all you need is an internet connection. Hopefully, as cheaper, reusable rockets become more available, more alternative services will emerge, which will drive prices down. Its growing popularity will hopefully make it more affordable as well.
    Tomasz Szabon
  • 14.  RE: On demand subscription is good but very expensive
    Posted 02-27-2025 09:11
    It does work well but there are improvements that should be made with on-demand.  1) For those of us who use Terraflex, the user should be able to check out hours through Terraflex instead of having to sign in to TMM, check out hours, disconnect/close TMM, open Terraflex, sign in, connect to DA2, then select the location service.  Going through multiple Trimble programs hampers productivity.  2) The on-demand service would be better if the user would be allowed to check un-used hours (tokens) back in rather than check out minimal hours to be safe and have to go through the process of checking out additional hours if needed.  For example, once the user is on the job site, the user could check out 8 hours but if the job was completed in the span of between 5 and 6 hours, then 2 hours could be checked back in and not lost.  These is my feedback as a user with multiple DA2 Catalyst units having used both on-demand and annual subscriptions.  Additionally, 60 cm should be standard for a DA2 with no charge for that level of accuracy.  I would expect this to be minimal with any external antenna bearing the Trimble brand.
    Daniel Bollich
  • 15.  RE: On demand subscription is good but very expensive
    Posted 10-24-2025 14:24
    Hi Daniel,
    I agree, switching between TMM and Terraflex is a bit cumbersome. Being able to check out hours directly in Terraflex and return unused hours would make the on-demand service much more flexible.
    Also, I see your point about 60 cm accuracy, it should be standard without extra cost. Thanks for sharing your feedback!
    ElaineW Chatman
  • 16.  RE: On demand subscription is good but very expensive
    Posted 10-26-2025 13:05
    Lol, this cracks me up. If you have been around long enough in this industry, you would know that the on-demand is VERY reasonable and is not remotely expensive. I do wish that they didn't have an hour minimum though. Honestly, if they charged 10% more for flexible use of on-demand, whereby you could use 15min increments, that would be a good licensing model!
    Zach Edwards
  • 17.  RE: On demand subscription is good but very expensive
    Posted 10-27-2025 13:15
    Dear Elaine Chatman,
    I'm writing to you directly in hopes of understanding how "Mapping and GIS Solutions Community" or "ConnectedCommunity.org" operates.
    I have been on the email list for years but never submitted a post until last week. I see correspondence go by with other people – sent to my email.
    I used Post New Message to ask a question. As far as I can tell my posting vanished. No confirmation. No answer.
    Can you tell me what to expect and when?
    Thanks,
    Michael Kennedy
    859-230-0191
    kennedy@uky.edu
    https://geography.as.uky.edu/users/kennedy
    It is Indeed Fortunate
    that God Designed the
    Universe along the
    Precise Lines of the
    Academic Disciplines.
    -- James Grier Miller
