There are free utilities available that will convert RINEX V4 &/or V3 to V2 for use with PFO. You have to do it manually, but they work fine.
At the easy end Emlid Studio is simplest to use, current version will convert V3 to V2
At the other end, GFZRNX is much more powerful with many other features and will convert V4 or V3 to V2 but it's complicated and not for the feint hearted. You may also need another utility CRX2RNX to decompress Hatanaka observation files. I have a command file to automate the process for PFO that makes it simpler than EMLID Studio.
John Winkler
Sent: 08-26-2023 17:03
Subject: Pathfinder Office and Differential Correction
I have been told that the ssf file format is not compatible with RINEX files 3.x and higher and that some CORS bases, such as those in Florida, have switched to storing their RINEX files in this format. Eventually, all CORS stations will switch to this format. Once the format is switched, Pathfinder Office will no longer be capable of differentially correcting ssf data. Not sure if this may be the case with the CORS stations you are trying to use.
Daniel Bollich
