Hi John, thank you for your reply and offer of assistance with coding tweaks. My organization has decided to go the route of upgrading our equipment and workflow to avoid PFO entirely by using ESRI FieldMaps on a TDC6 Trimble device connected to a DA2 Catalyst receiver. By going this route, we should still achieve our sub-meter accuracy goal using real-time corrections, and can save time by eliminating the post-processing step in our workflow. Thanks again for your input, I really appreciate your time.
Sent: 02-14-2025 19:56
Subject: Pathfinder Office Differential Correction - Cannot update base provider list
There are ways of converting RINEX 3 or 4 to 2.11 for PFO and continue using your local CORS for free.
I use the following command file and three utilities to automate the process. I keep these ready together in a folder and each time simply drop the downloaded RINEX into the same folder and double click the command file....and voila, there's the 2.11 with GPS & Glonass only ready to go for PFO.
Move the RINEX out before the next conversion, and select them in PFO with the browse or folder search options.
This example is for Geoscience Australia files but its easily adapted, for example if your download files don't use the same compression techniques you may be able to delete one or two steps and utilities. The content below needs to be copied and pasted into a text file and renamed to [your own name].cmd
I'm happy to help with any tweaks needed.
prompt $g
rem
rem 30Jun24 updated for gfzrnx V2.1.9
rem
rem ************************************************************************
rem ** **
rem ** Prepare Geoscience Australia GNSS Base Files for Pathfinder Office **
rem ** **
rem
rem Included options:
rem 7-Zip decompression
rem Decompress Hatanaka Observation File
rem Output only GPS & Glonass as Rinex 2.11 for PFO
rem
rem This command file expects the following utilites in the same folder:
rem 7z.dll " " " " "
rem
rem
rem Unzip downloaded GA base file package
7z e *.zip
rem Unzip individual compressed .gz files
forfiles /m "*.gz" /c "cmd /c 7z e @file"
forfiles /m "*.crx" /c "cmd /c crx2rnx.exe @file"
rem Convert Rinex V3 to V2 files including only GPS & Glonass
gfzrnx_2.1.9_win10_64 -finp *MO.rnx -fout ::RX2:: -satsys GR -vo 2
gfzrnx_2.1.9_win10_64 -finp *RN.rnx -fout ::RX2:: -vo 2
gfzrnx_2.1.9_win10_64 -finp *GN.rnx -fout ::RX2:: -vo 2
rem Optional - delete unwanted interim files
Del *.crx
Del *.gz
Del *.rnx
pause
John Winkler
Sent: 02-13-2025 19:42
Hi Leah,
We have been getting the same PFO errors here in NZ. What I found is that LINZ and Geonet have upgraded their base station format to RINEX v3.xx as of December 1, 2024, fully deprecating v2.11 in November. Pathfinder only supports RINEX v2.11 and below.
You might want to check with your base provider if RINEX v2.11 (or below) are still available.
In the meantime, our workaround is to manually download the RINEX v2.11 base data from Trimble VRSNow. Once downloaded, use the Browse option - see below:
Mary
Sent: 02-11-2025 09:04
I really appreciate you replying again, good to know I'm not the only one confused by some of this!
So to clarify, when you are using the manually downloaded CBS list saved to your computer hard drive, when you do the differential corrections do you use the "Base Provider Search" function or the "Folder Search" or "Browse" options to select your base data? Historically I always used the Base Provider Search, but that was when Trimble still hosted the FTP that automatically updated the CBS list. Are we still supposed to use that same Base Data workflow or is it completely outdated now? I was thinking in made more sense to use the "Browse" option and select the cbs_list.csv file that we saved to the C:, but when I select the .csv, I get an error message "One or more base files could not be loaded. Please check the base files, restart Differential Correction, and try again". I have no idea what to do and unfortunately can't find any help materials online that show manually downloaded data, they all use the Trimble FTP that no longer exists...
Leah C
Sent: 02-11-2025 08:42
Oh... I hope someone else answers. I probably shouldn't admit this, but I never look at the integrity index! :/ I always use the distance, plus I thought we were supposed to try to match the coordinate system the data was collected in? I don't fully understand that part though. Really, if I have a high percentage of locations >1 m off, I try the next base station on the list... but that probably isn't the proper way!
Alicia Jackson
Sent: 02-10-2025 14:21
Hi Alicia, thank you so much for this. I was confused before because I also wasn't seeing the old cbs list in the folder location that the support note directed us to, but it was in the ProgramData folder that you shared!
Now that I've replaced the cbs_list.csv with the new one, I'm still not completely sure how to proceed. In the past, I've always used the "Base Provider Search" in the Base Data field for the Differential Correction Wizard. When I go to select the base provider now, I'm still not seeing any integrity indices listed. Is that normal or is it a sign that I didn't properly update the cbs list in my files? How do I decide which Provider to select if I can't see their integrity index?
Leah C
Sent: 02-10-2025 11:11
Hi, thanks for this! I hadn't tried to update lately. Just a note that I did NOT already have a "cbs_list.csv" under Program Files (x86)\Common Files\Trimble\Config, but I DID have one under C:\ProgramData\Trimble\Config. I just copied the new file to both locations - not sure which one worked. (You may have to 'show hidden files and folders' to see your ProgramData folder.)
The ProgramData location is where we have had to update "user_list.xml" in the past, a list of user-defined base stations that our reseller (Duncan-Parnell) provided. Worth a shot if the other location doesn't seem to help!
Alicia Jackson
Sent: 02-07-2025 07:42
Hi Tom, thank you so much for your quick reply. I intend to look into the Pathfinder Office alternatives that you recommended, but am working on using the manual CBS list download you shared in the meantime. I've saved the .csv into the folder you directed me to, but I'm still not sure how to get the Differential Correction Wizard to utilize this list.
In the past, I have always used the "Base Provider Search" for base data during corrections. Am I supposed to select "Folder Search" now? If so, do I replace the Folder Search file pathway with the location of where I saved the .csv file?
Finally, do I need to regularly re-download an updated CBS list from the URL https://downloads.trimblegeospatial.com/CBSList/pfo/cbs_list.csv or is that a one-and-done action?
Thank you again for your help!
Leah C
Sent: 02-07-2025 05:38
Hi Leah
The Trimble FTP that hosts the CBS list has been shut down - take a look at the support bulletin here for more details including how you can continue to update the CBS list manually - Community Base Station List Distribution Update for Trimble GPS Pathfinder Office Software
In summary
NB - GPS Pathfinder Office was declared end of life in September 2022 so we recommend you look at the modern solutions we offer such as Terraflex and Terra Office which have tools to Import your existing Terrasync/PFO Data Dictionaries to greatly simplify the transition. You can reach out to your local Trimble reseller for more deatails
Tom Harrison
