Aaron,
Good morning. I intended on replying yesterday, but ran out of time. if you get stuck, give me a call and I can show you how to do this. I should have some time on Monday or late today (4pm).
Zach Edwards
Sent: 11-16-2023 10:21
Subject: Plot point/line in Penmap using distance and direction
Hello Aaron,
Yes, you can use the COGO tools in PMA to create points from one point. Under Topo/Construction you will find a number of tools to create points/lines. If you have one point set then you can use "Circle" to set the radius and then go back to "Bearing" to set the direction. These tools take a bit of playing around with to get used to them but they are a great way to create points and lines once familiar with how they all work. Here's a link to instructions to get you started.
If you are using ifeatures then keep in mind when creating a point/line the ifeature selected will be the feature created so you'll need to change when necessary.
Jeff Blanton
