Firstly. I want to thank you for posting you "issue" about the display in Trimble Connect regarding "polygon within polygon" as I believe it assisted me in a recent issue I was experiencing regarding the display of a models on my desktop computer vs display after uploading to Trimble Connect.
I had used the ValiArchitect Extension/plugin for windows/doors in a particular model. The desktop version appeared fine. Uploaded to TC and the windows/doors created with ValiArchitect appeared to have transparent or "cut-through" geometry filled with original material rather than transparent or "cut" as displayed in the desktop software version of SketchUp.
Your post lead me to test out "exploding" a window as a test. Initially, I only exploded an exterior window, uploaded that version and compared to the initial upload. There was an obvious difference.
I went back and exploded the interior view of that same window. Voila! I could then see through the window as intended (and as seen in the desktop model).
Exploded interior of same window on desktop then uploaded to TC...
A few more test uploads and a subsequent download of the original file (to see if it displayed as intended in the desktop software after uploading then downloading - all appeared as displayed in the original file).
Ultimately, I tagged all windows & doors with the same tag (layer), selected "All Tagged" then commenced to Explode again and again and again until it was demolished (kidding)...until each was exploded (it appears I may have missed a few but that shall be rectified soon):
Not an ideal workflow but sufficient for the time being until software compatibility issues can be rectified!
(It certainly did take a bit longer to "convert" the model in TC with doors/windows exploded.
Next I believe I'll Select All Tagged, group and then give it a go again for my own testing purposes (and hopefully minimize any lag due to file size)/
I'd love to hear any thoughts on the "issue" - suggestions welcome!!
Sharelle Quick
ZingleMedia
ResultantsCo
Admitted Nerdy Dork!
(Begging forgiveness for typos, especially those which occur post midnight in present time zone!) 0:-)
Sharelle Quick
