Trimble connect sync issue.
You change it but there is no change on the servers.
You reopen it and the old position is coming back.
Solution: complete reset of trimble connect (read everything first):
To do:
Trimble connect desktop issue that keeps changing the location.
Go to:
Local disk C/Users/*yourname*/.trimbleConnect/.files/
Remove the files in the folder and open Trimble connect desktop again to reload the files.
Step 2
Go to locale disk C:users/*yourname*/Appdata/Local/Trimble/Trimble Connect/
Notice that appdata folder can be hidden -> you need to go to the windows settings to unhide this ...
Remove the files in this folders ( notice that unpublished folders get removed also -> publische before if you need them ! )
Mike Denys
