Thanks Ruben. Fortunately I do not have to rely on moving models, and not using the Windows application version that much.
But also noticed that in my case only STEP files moved after 3 minutes of waiting, but DWGs in the same project not.
Best Regards,
T Laine
Sent: 03-20-2024 06:45
Subject: Position The Model
@Tero Laine I have always had that problem, my work around is to move the models using the app. save the view and open the view in my browser. Once I do that, I might see they are back to their original position, but then I can toggle the model off and back on and it pops into place. Its almost like the position settings isnt being read until you turn the model off, and then back on again.
Ruben Flores
Technical Director
TRC Worldwide Engineering, Inc.
217 Ward Circle
Brentwood, TN 37027-2314
Cell – 325-320-0719
rflores@trcww.com
http://www.trcww.com
Sent: 03-14-2024 00:52
Did anyone respond to you @Rauno Nuut ? I use mostly the browser version and rarely move models, but I was working on the TC for Windows and had to move some models and noticed how they seem to return to original place. Have you had similar problems when moving on browser?
Best Regards,
T Laine
Sent: 03-04-2024 03:44
I'm having the exact same problem. TC is not remembering the offsets I put in, it not only resets every IFC when reopening project and/or Trimble connect, but it also resets coordinates every few minutes when the model is open in front of me.
Rauno Nuut
