PROBLEM - CUT IN VIEWS
  • 1.  PROBLEM - CUT IN VIEWS
    Posted 01-31-2025 08:48
    Since Monday 27 or Tuesday 28, the functionality to move a clipping plane within a saved view in Trimble Connect Web has stopped working.
    I suspect this issue is due to the latest update, as everything was functioning correctly before this day.
    Do you know if this is affecting only my user, or is it a widespread issue?
    Thanks in advance
    Raul
  • 2.  RE: PROBLEM - CUT IN VIEWS
    Posted 02-03-2025 15:27
    I am having the same issues on my end as well
    Sampson Salinitri
  • 3.  RE: PROBLEM - CUT IN VIEWS
    I am having the same issue on my end
    Sampson Salinitri
  • 4.  RE: PROBLEM - CUT IN VIEWS
    Posted 02-04-2025 20:47
    Olá, estou tendo o mesmo problema.Por aí o problema foi solucionado?
    Paulo Henrique Gomes de Oliveira
