I downloaded the same plugin for Revit 2022 and Revit 2020 and facing the same issue. Also I tried to use it into my collogue system as well they are also facing the same issue. it crashes when i click on "Sign in"it frizzes here.<quillbot-extension-portal></quillbot-extension-portal>
Please provide a solution.
Thank you
I had to chek event viewer from windows, when i saw the revit application error and search in google,
i found this Autodeks first knowledge
the second step to review it was the revit Addins Addins
I used App Manager Diroots to disable enscape add in
And that's my solution
------------------------------Howard Flores------------------------------
