I tried that and so far it is working perfectly. Thanks!
Some notes for others with the same issue:
Start with the 5.09 rollback firmware. Updates say to not go further back than that.
Apply each available update from there to (almost) current 5.47.
(That may be tedious/superstitious it worked.)
I chose to not install 5.48 since that is what the R1 was running poorly before and the update didn’t apply to my region.
Noted that after the 5.09 rollback, the R1 stayed responsive without a lockup longer than it had in a year.
After 5.47, it ran for about an hour then locked up with the LEDs glowing white hot. I let the battery die & recharged. After that, it has worked perfectly through about 4 full battery cycles. Fingers crossed but that’s a new record.
Sent: 11/28/2021 6:41:00 PM
Subject: RE: R1 issue… reset possible?
Hi Mike (and others with similar problems)
I'd suggest trying to reload the firmware - that's the only thing which you can do at a User level which will thoroughly reset the unit. I'm afraid the long power button press just forces a restart, it doesn't clear satellite information etc.
You can find R1 firmware on the trimble.com web site by Googling "Trimble R1" - the latest is v5.48. Unlike other Trimble GNSS receivers, there are no restrictions on updates, but you'll need a Windows computer to run the installer.
Norman Smart
