Search by File Tags
  • 1.  Search by File Tags
    Posted 02-26-2017 04:22
    I have added Tags to files. How can I search/filter all files by those tags?
  • 2.  Re: Search by File Tags
    Posted 02-27-2017 21:22
    Hi Ahmed,
    User can add tags to the file but the Search and Filter feature currently not working with the file tags. However, we have this enhancement request in our backlog and once this feature is available on production, it will be very helpful using search and filter on the project. Stay tune and we will let you know once this feature is available on production.
    Best Regards,
    Fern Udomrasami
  • 3.  Re: Search by File Tags
    Posted 10-19-2017 07:13
    We also need to be able to search on the tags. Could you update us on when this feature will be released ?
    Thank you
  • 4.  RE: Re: Search by File Tags
    Posted 09-02-2022 09:59
    Use the tag operator to research for tags: tag:tagName
    https://docs.browser.connect.trimble.com/search/searching-in-projects
    Worked for me. Is this not what you meant?
    Best Regards,
    T Laine
  • 5.  RE: Re: Search by File Tags
    Posted 12-06-2023 07:53
    It does not work for me, can you tell me what sould I write in the search bar?
    Thanks
    Olivier Pellegrin
  • 6.  RE: Re: Search by File Tags
    Posted 12-08-2023 16:04
    Maybe it follows language setting and you need to use some other prefix like label: ?
    Best Regards,
    T Laine
  • 7.  RE: Re: Search by File Tags
    Posted 12-14-2023 07:07
    Hi Olivier!
    Tag search does not work all the time.
    We have had the same problem and support said that Dev team is
    on it.
    Antti Niittyoja
