Clearing site data, even if not much o it is in use, can help. My general search is now working.
Direct Project search not
But for example, the main search and limiting to projects only works
This is not the only problem where user is expected to do this step, while Trimble Connect itself is not able to fix its own problems.
CTRL+SHIFT+I, select application, then under storage, clear site data. Refresh and try again.
Best Regards,
T Laine
Sent: 11-25-2023 09:18
Subject: Searching CONNECT in web browser
Does this mean the older projects will remain unsearchable?
Best Regards,
T Laine
Sent: 11-13-2023 19:39
Dear All,
The Trimble Connect team is working on fixing the issue related to delay in search results for Connect for Browser. It is happening for projects recently created.
Darshan Rajaram Kamat
Sent: 11-10-2023 09:36
It is very difficult to be successful in project search in browser version. I stopped a while back when I noticed Trimble Connect Synch has fast and flawless Trimble Connect project search and you can find and open the right project in a matter of seconds.
Yes Trimble please fix the project search regardless.
Best Regards,
T Laine
