Sent: 08-21-2023 02:12
Subject: Re: Share folders between projects, Trimble connect
Hi Marco,
There are currently no plans in Trimble Connect to have Share Folder or to add folder to Releases.
We have noted your requests and valuable inputs.
Darshan Rajaram Kamat
Sent: 08-21-2023 02:08
Hello Tero,
I am aware about the multi-selection but this is not what I am looking for. It's important to be able to select at folder level when you have several folders to share or to add to the release. At the moment this option is not available in Trimble Connect and I am wondering if and when it will be available. Thanks,
Marco Perazzo
Sent: 08-19-2023 12:51
So you mean sharing without inviting to project?
About the releases, you can select the first file and Shift+select the last file and that selects all the files in between. Not greatest if folder has hundreds or even dozens of files, but much better than 100 clicks
Best Regards,
T Laine
Sent: 08-18-2023 01:23
Hello Tero,
I am looking for the option to share a folder in Trimble Connect web, same way as you can share one or more files with "share data" creating a link for member of the project or even any user with the link. I also noticed another issue we're having this time with the releases: there is no option at the moment to select an entire folder and add to a release. You need to select each file and add to the release, what is not suitable when you have hundreds of files. Is there any solution or future implementations for these two issues? Thanks,
Marco Perazzo
Sent: 08-15-2023 14:46
What do you mean exactly by "Sharing folders"? Sharing folders between projects, so updating files in one Trimble Connect project would propagate that change to other linked projects? As that is something we would find useful and separate internal and external communications based on the same models.
The original question was also about "envelope button" being available for files only. Is that request basically the same thing as inviting a person to the project and copy pasting the address from browser address bar? But some sharing option which would actually allow access to that specific folder...if you invite person in you would need to go through all folders to check Trimble Connect folder permissions so no one can see what they are not supposed to see.
Just trying to understand what type of sharing you are asking to see and if that is something I will support. :)
Best Regards,
T Laine
Sent: 08-14-2023 07:46
Hello Darshan, I see this post is quite old. Is there any plan to let users sharing folders in Trimble Connect? At the moment having only the option to share files is a big limitation in the software itself. Thanks,
Marco Perazzo
Sent: 07-14-2019 21:44
Hi @Marcel Reitsema,
Sharing folders with team members is not possible currently in Trimble Connect. Its possible to share just files within a project.
Your suggestion seems interesting. Trying to get some details on the expected behavior.
a. Are you requesting ability to share folders across projects?
b. If yes, can you please let us know how would we determine which user can share the folders across projects. Should it be the owning account or any other criteria? There are use cases where people from different companies / accounts share a project (Contractors for example). In such situations, should the access to share folders be restricted to only certain people ?
Can you please let us know your workflow and use case. It will help us determine the value of this feature.
Darshan Kamat
