I made a copy of my TBC project so I have the old WM design project. With the copied TBC project I selected the WM deisgn and pushed the ol delete button. It worked just like Pat said.
the bad thing is, i have taught myself to export my design through a VCL out to WM. well, I have not learned any other way and when I bring in my external deisgns. The VCL will not come thru as external designs. Now I have to delete all those designs from WM and start all over.
Francisco Guerrero
Sent: 05-11-2023 17:10
Subject: Switch Project inside TBC
i will give that a try in a week or so. we just had our base station tower extended and receiving good signal in those bad areas.
thank you Pat.
Francisco Guerrero
Sent: 05-11-2023 04:11
If you select in project explorer and use the delete key shortcut, you can "disconnect these". I would like to see a cleaner process in the future.
Patrick L'heureux
